Maistrelli
Can a 273 crank be used in a 5.2 Magnum engine? Magnum damper on 273 crank?
1965Balance has to be considered. I can't quite figure out if the crank balance is the same. Magnum 5.2L piston+pin+ring weights are very close to LA 318, but the Magnum rods may not be the same. I just don't have the rod data.
What year of 273 crank?
Doh! Of course I knew that....WTH?The fuel pump eccentric is on the camshaft, not the crankshaft.
Yes, that's a fit problem for the trannie. The OP would have to have the crank pilot hole turned out.The 1965 273 crankshaft has the small torque converter pilot diameter. Just so you're aware! 65'
If I was to mis match components I would have the machine shop properly balance the rotating assembly.Yes, that's a fit problem for the trannie. The OP would have to have the crank pilot hole turned out.
I worked out the bobweights with the data I have. 273 and 5.2L are pretty close but it still may be off enough to be 10-20 grams off of balance..... or some of my data is a bit off.
I think RRR is correct on both being neutral balanced for the dampers and TC/flex-plate/flywheel.
probably wanting a forged steel crank instead of castWhat we need to know is why the OP wants to put a 273 crank in a Magnum.
Well, the tolerance around a number may be that much, but what I am coming from is that the nominal numbers are that much off.I think 10-20g is within factory spec. Ive heard motors being much more out off the line.
I'm curious about that too.What we need to know is why the OP wants to put a 273 crank in a Magnum.
Oh just curious. Sometimes people have crazy ideas. It's more like why would you need to?Why is that pertinent? Might simply be what he has.......OR as has been said maybe he wants a steel crank. The why really doesn't change anything.
Using an A833, crankshaft has pilot bearing.The 1965 273 crankshaft has the small torque converter pilot diameter. Just so you're aware! 65'
Because I have a good one and 5.2M crank needs ground.What we need to know is why the OP wants to put a 273 crank in a Magnum.
It might work but there will be other things that won't be right. Why take the risk. Just turn and polish the Magnum crank.Because I have a good one and 5.2M crank needs ground.
I plan to have it balanced, new O.S. pistons, flywheel, clutch, PP and damper.If I was to mis match components I would have the machine shop properly balance the rotating assembly.
What's the average cost of -.020 rod & main journals? Anyone have crank ground lately? What others things won't be right?It might work but there will be other things that won't be right. Why take the risk. Just turn and polish the Magnum crank.
Balancing is going to cost 2-3 times grinding a crank. If you are not racing, then changing pistons to oversize does not necessitate a re-balance. So haw hard are you going to be running this engine?I plan to have it balanced, new O.S. pistons, flywheel, clutch, PP and damper.
