[WANTED] SB 727 inspection cover
daves66valiant
68 Dart 340/727:66 Signet Vert 340/5spd: 68 D100
SoCal
looking for SB 727 inspection cover.
Also need transmission bell to engine bolts.
And the engine to transmission support brackets
Galvanized inspection cover for 727 $20 plus the ride
Dave just so you know, there are different length engine to trans brackets for the drivers side (all pass side are the same). The 75 and newer brackets on a 360 are shorter on the drivers side than the older ones. Not sure on 318's. If your needing them for a 360 let me know the year and I'll look
Thanks Fishy. It’s for a 68 date code 340. Not sure about the year of the 727 though.
I ended up finding the whole setup on eBay. Hopefully the drivers side is correct.
My trans cover as stated above is a bit damaged. I have the correct 727 brace brackets from a 67 318/727.
Thx Greg. I found everything I needed including all the nuts and bolts. Got lucky on Ebag.
