Throttle bracket
moparmucelli
murrieta ca
hi guys I’m going to be converting my 360 2 barrel to a 4 barrel and I’m wondering if I can keep the throttle bracket that’s on it now or do I have to get a different bracket?
Also is there anything else I have to change to do the swap?
This will fit the edelbrock intake?
I use it on an Edelbrock Torker 340 with a Holley 650 DP carb. Only thing I had to do was use 2 slightly longer carb studs on the cable side as the bracket mounts on them. Otherwise it fits perfectly and looks very clean.
Installed
I have a stock set up that you can have. I have it posted on the Forum for another person but I am not privy to who gets it. First come first serve and i just wanna help. Peter 7345453794. I'll send it free.
well I use spacers under the 2 new longer bolts I install, then bend the bracket to aline it .
