moparmucelli
hi guys I’m going to be converting my 360 2 barrel to a 4 barrel and I’m wondering if I can keep the throttle bracket that’s on it now or do I have to get a different bracket?
Also is there anything else I have to change to do the swap?hi guys I’m going to be converting my 360 2 barrel to a 4 barrel and I’m wondering if I can keep the throttle bracket that’s on it now or do I have to get a different bracket?
Edelbrock performer 318/360What intake are you using?
This will fit the edelbrock intake?I run this and really like it. They come in different colors and polished. PRP 1324 Throttle Bracket Holley 4150 Carb Mopar Cable Made in the USA | eBay
I use it on an Edelbrock Torker 340 with a Holley 650 DP carb. Only thing I had to do was use 2 slightly longer carb studs on the cable side as the bracket mounts on them. Otherwise it fits perfectly and looks very clean.This will fit the edelbrock intake?
Can’t say. I don’t run one. Does not appear to have a provision for one.With that bracket how do u use a kickdown rod?
