Looking For Video Ideas
whitepunkonnitro
Murfreesboro Tn
We're going to start a Mopar tech Playlist for the Uncle Tony's Garage YouTube page.
Quickie one to three minute vids that pinpoint specific issues.
Help us out with getting a list together here.
Would this be slant six related too? How about a complete 2jz twin turbo build out of a mark 4 Supra in 2-5 mins? I got a car and engine/5 SPD trans ready to go!
If you need help video editing let me know Tony, I went to school for that and do stuff for people all the time editing that stuff for people in Nashville. How about starting with small upgrades like the voltage regulator? Rebuilding brake cylinders and calipers? How to setup and install the pertonix instead of using points? Carb adjustments? How to restore used parts to like new? Steering box adjustments for manual steering to get some of the slop out? Maybe general wiring troubleshooting? Rear diff fluid? Axle bearing replacements? I got a whole list lol
Here is a slant 6 car of his.
I guess I need to go look at other videos Uncle Tony has to get a better idea of what you are looking for, watching this thread..
I'll use the 'search' on Youtube to look for helpful videos to look for tips on something I have not done for a while, or have not done yet.
I do not recall seeing any of yours, but if anyone starts swearing in a video I am watching, I hit the back button to look for another source of info.
Big block valve stem seals, valve cover and exhaust manifold gasket replacement. I’ll supply the truck.
Wheel and tire fitment. How to measure for backspace and offset. A lot of people don't understand it. Don't know if you can do it in three minutes.
I also just did a relay for an extra fuse block. Damn if I could get that through my thick skull. Drove one of our member crazy with questions about correct wiring procedure for the relay.
There ya go , 70440dart . right on . # minute vids are not long enough to do anything . for inspiration : youtube " myvintageiron7512 " Great vids on engine building about 30 minutes each
I believe this ccan and should be dun, our member @cosgig had to show me with a few pictures and he made it very clear, thank you Geoff, I won't be wasting time and money now brother
You do have a whole list!
That Turbo 5speed Slant could be real interesting.
Message me your number, and let's talk about that
Why don t you come over and replace my wiper arm seals for me?
I'll hold the camera
Just throwing this out there. From what I understand, youtube can block your videos for using foul language. Doesn't bother me, just sayin.
Yep, as long as you avoid cuss words like, 'mustang,' or, 'chevelle,' you should be good...
Torsion bar adjustment
Mopar ign module quick testing (by grounding the connector)
Ballast resistor throughput testing
Throttle pressure adjustment
Bulkhead connector issue's
Headlight relays advantages
Frame connectors
Window trim removal & repl
Firing order explained
Trans band adjustments
Ujoint replace
Trans and motor mounts
I have already heard the car run and seen video of it driving. I’ve paid the deposit through a broker for the engine/trans/harness/ecu from a company in japan. It will be June or July before it is actually here at my house plus I have one debt to pay off here in the next few weeks. It’ll be on the way by end of March and then take it’s long journey through customs etc. talking with a guy in New Jersey who has already done the swap and per his words...... it literally drops right in. Just have to make the brackets to adapt the engine mounts. I’ll call you this week if your number hasn’t changed once I get pics of the one in New Jersey. It’s a 72 dart but same pretty much as an early a body
Man
I would really like to see pinion angle covered. We all know it is important. I would like to see it covered in an other than stock set up. Where maybe the motor was set back , or a non stock motor added or different rear axle (non mopar)utilized.
Dont know if a short vid could cover that.
An episode explaining how you wound up in the Hinterlands could be highly entertaining. Seems like the damnedest thing, has to be some sort of story behind that.
An episode on the old Mudd Brothers story would be fun!
Just an opinion. You have a lot of knowledge to share. Slow it down and go a little more in depth.
