Show your wheels
What a damn beautiful car. If I was new car shopping in 1971 or so, there's nothing I would have picked over a Duster like yours. Drive in good health, sir. And of course, you can't go wrong with Mopar Rally Wheels.
BBP Jegs wheels. 15x8 with 5.5" backspacing and 255-60-15s in the rear, 15x4 with not enough backspacing in the front and have 185-60-15s on them.
These look sharp! Do you remember the name of this wheel? They almost look like Weld wheels.
Sorry for the late reply, I haven't logged in lately. I'm fairly certain these are the exact one's I'm using:
JEGS 681277: SSR Star Wheel Diameter & Width: 15 x 8" | JEGS
JEGS 681251: SSR Star Wheel Diameter & Width: 15 x 4" | JEGS
Finding a tire for the front wheels was a pain though. The lack of backspacing made it hard to avoid catching the fender in the front.
Dart rims with spacers on the valiant
Here is my progression, starting with the (Yikes!) red 13" steelies that were on it when I bought it.
Then I found a set of 14" steelies on CL. 4.5" wide in front, 7" wide in the rear. Tires are 205/70 in front, 245/60 in the rear. The guy I got them from made the rears from some (Ford) :eek: 7" rims he welded to SBP hubs. They fit with just enough clearance.
There's a custom paint shop in town, I took the car to them and they mixed up some rattle cans to match the car, so now it's the same as the yellow wheels but painted to match the body. These are all SBP. I like the look and stance of these so won't likely be changing them. I did find a set of 14x5.5 front rims so will be swapping those in, but don't think it will change the look much.
18 x 10 rear wheels with 295/45R18 rubber
16 x 7 wheels on the fronts with 205/50R16 rubber
I mix it up from time to time. Several difference sets in my Charger from Rallyes, to Cragars, to Steelies. I have Magnum 500's on Charger #2 (sorry, no pictures). I have Weld Magnum 2.0's on my Challenger.
These will be on my car, 15x7 front, 15x10 back with 5" backspace, 205/60/15 front, 315/60/15 MT DR in the rear. Jegs ssr spikes made by vision.
18"x9.5" Coys C-33 wheels. Mocked up with poverty caps.
Have to swap front end over to big bolt pattern, then will have matching wheels front and back.
