RPMagoo
Just An Old Motorhead
The Tire Manufacturers indicate that with a 295/50-15" tire, the minimum wheel width is 8 inches. -- This seems too narrow for a tire of that size. -- Has anyone done that, and/or comments ? --- Thanks
;I try to run with the wideset wheel for the tire used. This keeps more tread on the ground and less stress on the tire mounted to the wheel so it doesn’t bulge. A narrower wheel may work but I don’t like it.
The same is also true in reverse. I don’t like to stretch the tires ability to seal against a wide wheel.
Do you have a shot of this?Totally agree with your thoughts on that.
245/40's on 9.5 wheels
Section width of the tire is 9.5 inches.
I wanted as much rim as I could get and as far out to the fender as I could get it.
After moving the leafs 1/2 inboard I have 1" on each side of the tires inside the fenders after trimming 1/2 off the inside lip, and 1/2 inch from the rim/tire to the springs.
Probably could have done 255's but didn't want to push my luck.
Of course it took me months of investigation and surfing the tire and wheel places before I felt ready to commit that much money to something I couldn't physically try on the car first, but in the end they fit perfect.
Seems like a narrow tire. My Scat Pack came with 275s on 9.5s. My Dart is 275 35s on 9s.
I had the fenders removed and stored while I repaired the front structure and repainted the engine compartment.Car color is kick ***, whats the tape for ?
AH SO , nice .I had the fenders removed and stored while I repaired the front structure and repainted the engine compartment.
Like I said , I agree with all the above posts , but they are radials and have flexable sidewalls to start with, letting a little extra air out of them to get the contact patch flat on the ground aint that big a deal. " If ur not trying to make a corner carver out of it "------I have to say that the tires on @steve340demon 's car look pretty badass but yeah, I think the general consensus is right on in this thread. 8" technically will hold a 295 tire but you're far from the optimal contact patch, meaning that you're accelerating a bunch of tire mass that you're not putting to good use.
To some degree this is going to depend on the intended use and the design of the particular tire. Personally, I'd want a 10" wide wheel before I even thought about a 295. I am running a square 285/35/19 setup on my Mustang with 9.5" wide wheels. The sidewalls are holding up, the tread is wearing pretty well...but even this is technically less than ideal.
I`m thinking seriously about putting the 295 60 15 d.r. back on my 68 fastback, cant find anything much better (bigger) that I can get under it, being non tubbed. Really would like to have sticky tread tho. Been looking at 295 60 d15 hoosier quick times, but don't think the sidewalls would clear, as they are wider than my 295 drag radials.
Yeah, if you're not trying to make a corner carver out of it, I guess you have a few more options. I believe that drag radials in particular are more accommodating to playing with the tire pressure...though I've never owned a set so I'm just going on what I've been told.
Otherwise, you might be ok for accelerating and braking but if you need to steer hard, you're certainly going to notice those squirming tires.
Why not spend a few bucks and get wheels that can take advantage of the extra surface area?
Ya there is no doubt that they should be on 10” rim, but I had to squeeze these 295s in there on 8” with spring relocate and I wanted them inside wheel lip.. as for handling these A bodies never handled with stock suspension.. this is jus cruiser with 340 4 speed with big boots on back if know what mean
sidewall would clear!
Same here . Altho I wouldn`t exactly call mine a cruiser. Its a toy.
I don't agree about A bodies not handleing. In 1968 I bought a new 383 fomula S fastback, I bought it in Tulsa, drove it home on the hi way, around the small hick town I lived outside of that night, (lot of dragging main) , a little showing off.Ya there is no doubt that they should be on 10” rim, but I had to squeeze these 295s in there on 8” with spring relocate and I wanted them inside wheel lip.. as for handling these A bodies never handled with stock suspension.. this is jus cruiser with 340 4 speed with big boots on back if know what mean
The next day I took off to return o the air base I was stationed at. I got into a race w/ a volkswagwn ...
We were racing thru the Ozark mpountains , before interstate 40 was done back then. I could run of and leave them both w/o much trouble !
I get your point about a VW being a light weight, relatively nimble car for it's day but I have to admit that the thought of comparing a VW against a big block A-body is mildly hilarious.
