With long rubber gloves, a full respirator, and throw away old clothes, I sprayed everything down, removed the seats, and put the carpet and any nest material into a large heavy duty garbage bag and sealed it up.
Then mixed a good amount of simple green and water in a bucket, multiple times, and dumped it all over, inside, down the cowl, in doors, trunk, everywhere.
Then sprayed it all down again to get the suds going.
Scrubbed everything with a nylon brush.
Pulled the body plugs and sprayed it out.
Repeat if needed.
Btw, I have a hot water outdoor spigot, install one if you don't, you'll wonder why you didn't do it sooner.
To prevent mice/rodents, I took a leftover cedar 2x4 piece from a swingset kit and threw it on the back floor. Slicing a thin piece off the end every year doesn't hurt either.
Not a rodent since.
