[WANTED] Engine brackets LA engine 67-72 (bolts to block, not the pad)
I do not believe Mancini has those brackets.
The left side bracket is different for 340,360. the right side is the same for all 273,318,340,360. 67-72
I didn't know they were going for that much. They are the same as what I have but I do not include the used rubber pad. I can but they have new interlocking mounts that don't rip , Most use the new mounts
That was the first one I came across, there are more down the page in the 160 to 180 range used.
Well I have what you need. If you don't find them. I have one set of 340 360 left that I will sell as a pair only.
