Borgeson steering box
DusterDaddy
sledgehammer mechanic
Holmdel, NJ
I just installed a Borgeson power steering box in my 74 Duster.
Summit sent the box for 72 that has the smaller 1-1/8 pitman shaft
Will a pitman arm for a 72 work in my otherwise stock 74 steering setup?
Ok men. The car is back on the road and man oh man, the box gives you great feel of the road at about the firmness of a modern Challenger.
I am running stock V8 torsion bars, stock suspension with all Moog parts, along with a Hellwig sway bar.
Only departure from the norm are the coil over front shocks that are normally run on Ford ranger pickups. The car stays nice and flat in the corners. A bit unconventional but it works great for me. They were a tip from the local Chrysler guru...
The coil-overs just help the torsion bars do their job, which also shows that larger torsion bars (increased springrate) pretty much always improve ride quality and (even normal) handling.
The Borgeson costs a bit of money but is well worth it and brings an old car's steering control up to a whole new level.
View attachment 1715226208 View attachment 1715226209 Ok men. The car is back on the road and man oh man, the box gives you great feel of the road at about the firmness of a modern Challenger.
What ratio is that box?
wait a sec.....You are running coil overs AND torsion bars? Did I miss something? I love the idea, and like to know how to do that. What are the attachment points? Is it the same as just going to a 1.03 torsion bar?
Thanks!
Thanks!
Father-Son 1974 Duster Project
See post 2112
They are just coil over shocks.Also see post 5 in this thread above. Got the idea from an old timer at the local garage. They make a difference with the stock V8 torsion bars and I think they look cool too.
Thanks!
See post 2112
I can sort of understand doing something like this in the seventies or eighties when there wasn’t very many options for upgrading the woefully inadequate stock torsion bars. But there’s no reason to do it now.
Do it right, buy a set of 1.03” (or bigger!) torsion bars. You’ll actually know what your wheel rate will be, you can match your shocks to the wheel rate of your torsion bars, and you’re not putting additional loads on the shock mounting points.
That way you won’t have some goofy light truck spring-over-shock fighting with the stock torsion bars for control of your car. They’re a band aid for the trucks, and they’re a band aid and the wrong application for our cars. As for how much spring rate they add, who knows? Gabriel says their rear shocks can add as much as 500 lbs of “load capacity”. What that translates to in spring rate depends on what they actually mean by that. The fronts are supposed to be a constant rate, the rears are variable. But they’re just a band aid to keep your stock suspension from sagging. Even the trucks would be better off without them. If you need these things, what you actually need is new springs that match what you’re doing with your vehicle.
Nothing fights with anything in my car. It’s all peace, harmony, and love.
Thanks for your concern, but she drives great and is a dream come true to me...
