Flywheel balance
Ceedawg
Va
im would like to use a zero balance flywheel on a 74 440 cast crank engine. Need to know where to drill and how much to allow for the external balance.
Is your crank drilled deep enough for the input shaft of the manual trans? Is your crank reamed to accept a pilot bushing? Do you have access to a 31/32" drill bit? If not a 1.00" will work. Do you have a fax# the "blueprints" can be sent to?
I'll go look now. Got a fax machine but out of ink. Email-text I can do.
No hole, but I do have the bearing that fits the converter snout hole.
E-mail-text wont work for a blueprint. Maybe someone near you has a fax.
Try to send, might get it on a flash drive then to my other printer, 5407752059
Let me know before you send, have to turn on
