looking for kickdown linkage for an A body 360 to 727 transmission. Only in need of the one linkage from the bracket to the transmission. Would need shipped to Canada
You can use one off a M-Body with the adjuster on it to. It will be off of a 904 but with the adjuster and some work it will work. You maybe able to find one up there.
Not sure about that, haven't tried. I have used them on 70-72 340/727 combo and 360/904. I'm sure you could make it work. It's nice to have the adjustment down on the transmission as well as up at the carb. It is just about a direct fit on the 360/904. If your running a 4 barrel the bell crank on the transmission housing must be correct but the rods can be made to work just fine.
