j par
Well-hung Member
Another thread killed with kindness...
as a PS you might find a non-running or swapped out 360 4bbl & IF. No wiped lobes on the Cam (& its the 203/203 one & not the 115LCA one) just swap eveythiing over with a fresh T/chain,
It ain’t me! He got upset over what he thought was myself calling him crazy as if fact. Truth be told, I might be right. For starters, using local lingo can be confusing to others.Another thread killed with kindness...
Faster than the light turns green & some TURD up your A honks - Like the watch: Fcuk-off ya OCD Iriot. You forgot your Zoloft & Ritalyn.Oh! You my *** hat friend was just doing so good on letting the ball drop back down to a normal status. I’ll bust out the downward staircase back to your level just for you. Since that is where most dirty used asswipes fall, below foot level.
There is no way I’m following you around but talk some stupid **** again and I will as not to disappoint you.
Now show me where I said that you “clearly intimated” your baseless charge. Your post was suggestive of doing so.
I also rebuke your “more area undercurve” statement. A few degrees and more lift doesn’t suggest or prove there is a greater lobe intensity underway. This coupled with your statement of the Summit cam be a lesser cam.
If such is true, please do so provide your proof!
PS, to anyone looking at the intake mentioned on e-bay, there is one for sale here in the classifieds.
Now IF only half of that made sense to the general public here in FABO, as well as myself, I might, just might be able to formulate a reasonable retort.Faster than the light turns green & some TURD up your A honks - Like the watch: Fcuk-off ya OCD Iriot. You forgot your Zoloft & Ritalyn.
Now your not getting anymore oxygen, behind your 386 with Win95 (at best).
By this, it means you just want to post argumentative posts and continue this mess.Faster than the light turns green
AKA = Up my ***?& some TURD up your A honks - Like the watch:
AND SO! I googled what you said was spelled right. Here is what I found;Fcuk-off ya OCD Iriot.
The silly baseless accusation. But since you seem to repeat yourself on it, you must personally know the effects of being on and off the drug.You forgot your Zoloft & Ritalyn.
Plenty here at sea level! Thank you for your concern. Come off the mountain and enjoy some real oxygen content.Now your not getting anymore oxygen,
I have no idea what this means. Speak English!!!!!!behind your 386 with Win95 (at best).
Well, that's a somewhat ambiguous comment, but like the guy in Finland, it could all depend on what your transport/shipping costs etc are & ultimately the original suitability v buying cost can have a big bearing on if cost effective or not ( or as others have noticed whether a certain someone's knickers' in an increasing twist, keeps leaving his skidmark on more threads )My take on it is........ there sure seems to be some panties in a bunch over a thread that might pertain to five people in the world who might consider using a 360-2bbl cam in a 318 as a low buck upgrade.
Whew, Sorry to read someone is upset over nothing.( or as others have noticed whether a certain someone's knickers' in an increasing twist, keeps leaving his skidmark on more threads )
1: You have already been found out to be a lair so there is no way I’d ever believe that.( ALSO at the time had 1 of the 2 Founding Partners of then Competition Cams phone me from States asking IF I wanted the Australasian Distributorship: eat your heart out pantypal360)
Hell, I’ll pay for airfare on over so you see my lips speak to you if you want. Try me.had involvement since at least early-mid 70's with NZL's top Cam grinding Co & have had my own line of Custom ground & reground Cams,(& STILL DO) I'm afraid I DON'T take kindly to some faceless fruitloop Continually having a crack, cutting n pasting ( out of context etc, having to do net search's to try & get a handle on the self explanatory ) Trying to trip me up, bullying type accusing crap not in your dreams said to ones face
WOW, so many insults integrated it’s almost ridiculous. I applaud you. Must have had help., so against my better judgement, I've incl pics of Both New billet unused OEM grind Cams: 360 2bbl on left, std 318 Can ( M military) lobes on right. Same base-circle diameters: Its Plainly obvious ( to my skilled experienced eye anyhow ) which is the bigger lobe ...I can look at many Cams & tell pretty much straight off, particularly cams side by side, looking at paired intake & exh lobes whether they are narrow or widely ground lobe spread,roughly how aggressive & few other trucks of trade. All it takes is a lathe even or cylindrical grinder set up to measure a cam. The Jerk events on the 360ci 2bbl Cam are pretty smooth, Even & nothing horrible, like a couple if spots on SBC OEM 327/350 Hyd , & SORRY PANTY SCRUNCHER: There's obviously, given the tad extra lift, quite a bit more 'area under the curve' than the VERY mild 318 std Cam. Sorry Pal, IS the Cam business part of 1 of your vocations ?? Hmmm (skidmark360) ?? - not above poster , who's level of basic comprehension is increasingly Elementary school, IF that.
I've had & measured both Cams: I've done my homework.
Jesus Chrißt for the 1st time in living history NZ has just had a Terrorist attack with 49 shot dead, With 2 killer earthquakes 8 years before same city & some clown cut n pastes trying to bolster His own loudmouth tiny Ego ?
Hey Pal do your worst : water off a Ducks back.
Puh!.
...dumbed-down nob.(OCDskidmark360) now dry up & blow away, you are ruining perfectly good threads - OR is that the intention. :-/
