Porta power awesomeness
moparmandan
Deland, FL
I commented about this on my build page but wanted more opinions on this bad *** tool. Because of my inexperience, AMD and Ma Mopar's tolerence's my right front fender fit a little tight. It needed about a half inch to fit correctly. Instead of hacking, cutting, re-welding the upper radiator support, I decided to buy a new tool and just move it out. Always wanted to play with one. What else can we do with these things? Worked awesome, and the fender fits fine now.
View attachment 1715303690 View attachment 1715303691 View attachment 1715303692 View attachment 1715303693
I have one of those and love it.
The first job I did with it was to reposition some bent bumper brackets, which it handled very well.
I also used it to push a pillar back out on a car that got T boned.
You can move pretty much anything if you have a backstop to push against.
Great tool for experienced tree cutters that are cutting a tree leaning the wrong way, too!
I have a cheapo porta power too. Should have sprung for the 10 ton.
Its a very handy tool.
That and a ratcheting load binder the truckers use. They pull really hard.
I got cheapo 10 ton push 5 ton pull !! The monkey stick sounds fine , several different leverage bars would be nice.
Load binders are very good, my all time favorite was a Wyeth-Scott & Co. Red Devil come along. Also known as the More Power Puller.
I too, have one of the Harbor Freight Porta-Power Tools. I actually bought it, because of a fair size dent in the left rear fender of my '07 Charger R/T, only, the way the body is built on that one, I can't see where I could put the base of the Porta-Power against, that would be stable enough, to push against. I have used them, in past years, but cars were built a lot different back then.
Thats where a cushion and plywood comes in.
Thanks, I will have to give that a shot. When I was going to attempt to use it on my car, it made me back off, because I sure didn't want to add to my problem & the next thing I knew, because of other issues, time went by & I hadn't gotten back to working on that again. But now, I want to get back to it & will give your suggestion a shot, to see how it goes. :thumbsup:
I used one to swell the fenders on a 67 belvedere for bigger tires, before we tubbed it. 2X4`S ROUNDED AND TAPERED ON THE ENDS, WORKING SLOWLY AND CONTINUALL FITTING OF THE BOARDS, WORKED PRETTY DARN GOOD .
disregard caps ---
Used to have a short ram porto-power welded on top of the rf spring/weight jack on my dirt late model back in the 60's. Mounted the pump on a down bar on the right side of the seat.... allowed the car to adjust the weight while racing.
Still have the porto- power under the bench.
Bought the big one from Harbor garbage. Broke one of the ends trying to press out 8.8 axle tubes. Returned for another. Works great otherwise
