[WANTED] 1970-1972 Valiant/Duster HOOD HINGES
Duster and dart latch assembly are different..hood hinges are same but holes changed a bit in 73
The holes were changed in 72. What year hood do you have. I have what ever you need but you have to know the year of the hood you are using. 72 and up A-body hoods have stationary mounting threads so the hinges have larger relocated holes
Yes, I am interested....Please send photos.
My hood bolt pattern is 4 1/4". Do you have the safety latch and the striker rod?
My hinge is the top one. I ordered a fiberglass bolt on hood for a 1970 Duster. These hinges do have the springs??? I also would like the safety latch and striker arm. How do I get invoiced? New to this site and not so good on a computer. Also I do plan on two hood pins on the front.
those springs wont work for fiberglass...need low tension springs..will crack the hood if not
I am going to have the springs reworked so as they are low tension.
that's why I need a different set up. I will not do the spring alteration on my OEM springs. I save all OEM parts.
Ok.kool..I know it requires a spring half the width as oem...somehow they split it down middle of just mill half off of it...idk...need a pair myself for my AAR..lmao
When ever you use a fiberglass bolt on hood you need to install 72-76 hinges.The style on the bottom. It doesn't matter what you ordered the hood for. all fiberglass hoods have stationary threads in the hood.
Not trying to disagree with oldmanmopar but my fiberglass aar hood hinge bolts are adjustable .they are not stationary ..you really need to check hood first
Mr. Sinster,
I sorry that I got mixed up on who I was talking to.
I have purchased the hinges all ready.
Again I am sorry
