Trunk extension replacement help
mopardemon340
WI
So I'm replacing the trunk extension panels in my 72 demon. How do I remove the brackets that are attached to the extension so I can replace the entire extension and not cut and splice
Find the spot welds and drill them out. A wire brush, good light is your friend here..
This is only attached with spot welds and one bolt?
I did the extensions on my Duster I ended up buying new brackets instead of re-using mine
