costan
New Member
Hi folks,
I've got a 68 Barracuda with some gauge issues:
After poking around this forum, I suspect this is likely either a bad voltage limiter or possibly a short to ground between the sending unit and the gas gauge (as RedFish suggested here).
Before I order a new voltage limiter and figure out how to pull the gauge cluster, does anyone know how I could rule out a short to ground or other issues?
- Gas: Rises to full when key turns on, slowly falls to empty when key turns off
- Temp: Always stays at C indicator
- Oil Pressure: Always stays at low indication
- Alternator: Always stays in the middle
