engine stand mounting
Kenz68
Member
Sacramento, CA
This may be a stupid question and i have tried searching but im not sure how to properly mount the new hemi to an engine stand. The bottom mounts are incorporated into the oil pan and the rest on top. Do i just attach all 4 mounts to the top of the block?
Negative Ghostrider.
Take the oil pan off.
Bottom holes both sides for the lower engine stand mounts.
Top 2 holes for the top engine stand mounts.
Yes, I took it off to get it on the stand and just a couple bolts to hold it on while I painted.
You can leave it on. I just re-read the original post.
Sorry I wasn’t specific in my original post but I need to remove the oil pan. I see how you have it set up and I will do it that way. Thank you
Yeah, I’m confused. The bottom mounts are not near the pan.
I’m about to put mine on a stand as well so understanding the challenges of mounting it would be good....
Thanks for the feedback
