Twin scoops on a notchback?
RSie
Idiot In Training
Wisconsin
I'm thinking again, which right now is all I can afford to do. :)
I have a '69 Notch, which currently has a '68 hood and nose piece. I have a '74 Dart hood, which I think is the 'correct' (appearing, anyway) hood for the car, and yes I know about the hinge/hood mount hole difference. If I can find a nose piece sometime, I'd like to put the twin scoop setup (the separate scoops, not the twin one-piece scoop.. two separate ones about where the heads would be, like on the Darts and Dusters). I think it'd look nice on it, and it's still 'Mopar-ish' appearing.
I've looked all over and never seen one like this.. has anyone?
Thoughts welcome :)
I should have taken a picture. I was at an auction this last weekend that had a 67 fastback. It had the Dart scoops on it. Didn't look too bad. Could have done without the Go-Wing on the back .
Here's the sale bill. Upper left.
If you're gonna put two scoops on a '69 notch. This would be the proper way.:thumbsup:
Flat hood unless you have intake that requires a scoop.
Twin scoops only when it's factory...even them I'd be tempted to replace with flat.
Flat hoods are sexy. :)
Yes when it is all under! Or you just prefer that stock look for your 69.
The twin snorkel fits nice and looks great but took mine off.
I don't like go-wings. I think though, that a small spoiler like a '69 camaro had, might look nice on a notch.
I've also thought about opening the hood up the entire length of those scoops. Not for cool intake air, but to lower under hood temps. They are right over the heads/exhaust manifolds.. lot of heat would leak out in traffic, and maybe a bit of downstream air on the highway. As I said, I have time for thinking :)
This is my old race car with a 75 dart sport hood. On my current car I found a set of butchered cuda scoops and made them functional, using the same rubber rings as the dual scoops on the darts.
I vote, as usual, make it to fit your tastes.
I also have a few F bodies, the snorkel scoop is added by many people although it was never factory. I like the look. But I tend to be more correct with other models. All in what you like.
There used to be a pic of a notchback with a shaker hood...I thought it looked awesome
Jeff
Build it your way! I've added the (now functional) twin scoops, the V21 style paint treatment and '70 Rallye wheels to my Dart GT. I like it.
