Plymouth_Ruster
"I'm a profeshunel"
Was going to keep a slant six in this car, but I was recently offered a pretty good deal on a 440/727. I already know doing RB swaps on later Dusters is an absolute pain because they're not as popular, But I need some help with this.
I already know which engine mounts I need, part #SCHA73B6 from Mancini Racing. Obviously I'll also need a different radiator and a few other things.
So I know I need:
-Radiator
-Drive shaft
-Either a Chysler 8 3/4 or Ford 9 inch differential (or a Ford 8.8, looks like the easiest and cheapest option)
-Headers that will fit an A-body with power steering (looking at Schumacher)
-Engine mounts (already found)
-Transmission lines (going to use flexible metal brake line for this, or apparently they just sell them)
-P/S pump
-Camshaft (RV cams are alright but I don't need the car to pull three times its own weight) -have several options for this
-Different carb, probably (holley 750 looks like the go-to here)
-Transmission yoke
-Engine already has accessory brackets on it
-Trans linkage (these are sold several places)
-Blower motor modifications
-Front-sump pan & pickup
-Mini starter
Will also check out the Schumacher conversion kits later.
Lemme know what you else you guys think I'll need that isn't listed here, as well as where to get those parts. The headers are what I'm currently most worried about.
So I know I need:
-Radiator
-Drive shaft
-P/S pump
-Transmission yoke
-Mini starter
