Leaf Spring Mounts
hoosierdaddy
Central Indiana
Is it possible to flip the leaf spring front mounts without totally removing the leaf spring ? 72 Duster
The bolt pattern where it bolts to the frame is offset so it only goes on the right way. But I guess you could re drill the mounting bracket.
Are you trying to lower the rear? They sell front leaf mounts that do just that. 65'
Agree^^^ Flipping the hanger is not as simple as unbolting it and flipping it over.
Are you trying to raise or lower the rear?
Trying to lower the car but after looking closer at the mounts I've decided not to go that route . I didn't like the change of pinion angle . I have new stock leafs that haven't settled yet and I don't care for the look
You could use lowering blocks, minimum pinion angle change. 65'
