I've been piston shopping for my next 5.9 Magnum turbo build and have found a few forged flat tops with basically the same specs across many brands; ICON, JE, Wiseco.
The Wisecos seem to be the best priced (as low as $409 w/ rings). I realize they aren't necessarily a turbo piston and will put compression at around 10.5:1 but they seem like a good bargain for a forged piston and my goals (about 15psi max).
Im thinking about these pistons, stock crank and the good Scat I beam rods. Stock bore and stroke, E85 fuel. Thoughts?
Hughes Engines
Hughes Engines
