ValiantKindOfGuy
Hey guys I have a 68 valiant with a 8 1/4 rear end disk in the front drum in the back. I’m looking at a set of 14x7 wheels with 4” backspacing with 195/70/r14 tires on them. Will they fit??
4.5 not sure what the rear is I’m assuming it’s a body lol. I just bought it. It has an unknown disk conversion in the front as well.Kind of a narrow tire for a 7" wide wheel. Are you still 5x4" bolt pattern? Is the 8-1/4 original, I didn't think they had them in 68?
Tell us more about your car.
All true. I’ll have to take some WMS measurements. The front currently has a 14in steely on it. I will take a picture of the front brakes and the number on the dif and see if that helps. Sorry for the bogus post.It would help to identify your disk brake conversion and the width of the rear axle.
Since neither of those parts is original to your car, we really can’t give you a good recommendation. If you have A-body parts then those wheels should fit, but if you don’t then who knows? Could be an 8 1/4 out of an F body. Or a Dakota. Hard to say without measurements or pictures.
