What kind of power would you guys expect to the wheels with this setup?
The car is quick, but I though it would be faster. Timing is dead nuts, afr’s are on the rich side at 12:1 at the top.
I have a 360 .030 over
Zero decked the block with KB flat tops
CR at 10.5:1
Imm EQ worked magnum heads 1.6rr
2.02 1.88
Dual plane Eddy intake
Electronic distributor
3:91’s
PTC converter custom spec’d For my setup, great converter, flashes to 3900.
Lunati Voodoo cam specs as follows
Advertised Duration (Int/Exh): 262/268; Duration @ .050 (Int/Exh): 220/226; Gross Valve Lift (Int/Exh): .475/.494; LSA/ICL: 112/108; Valve Lash (Int/Exh): Hyd/Hyd;
CR at 10.5:1
2.02 1.88
3:91’s
