[WANTED] 273 4 barrel intake 64
1964Dart273
New Member
Molalla Oregon
Rating - 0%
0   0   0
Looking to upgrade to bigger intake and carb on my 1964 273 Dart. I understand they can be difficult to find. Preferably aluminum, but would consider stock. Thank you. Phone number removed by staff.
Stock cast 65 4 barrel manifold is casting number# 2465726. (no 4 barrel 273's in 64) Edelbrock made a D4B which is aluminum and harder to find than the stock cast manifold. The 64 and 65 273's had a smaller attaching bolt and at a different angle than the 66 on up small block manifolds. The newer manifold bolt holes can be modified to work if you choose.
Any small block manifold will fit. All 66 and newer manifolds will have to be modified. Ones specifically made for the 273/318 will have the correct port size.
By the way, Welcome to FABO. Love your 64. I was looking for one when I found my 66 15 years ago.
Understood. Is there anyone who still manufacturers a manifold that can be modified? If so do you know the part #? Been looking for a D4B for a few weeks now. Thanks. I have learned so much on this site.
Thank you! Worked on it all summer to get it on the road. My wife and 3 daughters love that car, me as well. Its my daily driver. I sincerely appreciate all the help!
I’ve got a cast iron intake and a D4B. The D4B is in decent shape I bought it off here and ended up using a LD4B instead with 66 heads. I’m in Springfield Oregon.
I have a 4bbl but the choke bowl has been modified, cut out for a holley I believe.
