Stop in for a cup of coffee
hows that fire going?
Didn’t light one yet... split some more and changed engine oil
Did PG&E do their public safety shut off last night?
No, the new shut off I think might be around tomorrow evening at 1800 to 2000 military time.
The fire is still going strong, now about 22000 a few. 40 - 50 structures burned. It is still in a rural area, not much people there.
Thick with smoke here today, came all of a sudden. Maybe the pics I sent show it.
Bill
Bill
looked a bit hazy so that's why I asked. still heading towards ya?
Digging into rear differential, bearings showing wear,pitting. Some uneven marks on bearing cups. Theres filings, not sure where they are from. 2010, third time it has been apart. And pinion jingles when i spin it. Cage is loose? Wont know until i pull it apart.
Just came from my last physical therapy session
They want me to go back because they are saying I have "knee valgus"
I never even heard of that before but he showed me how when I stand straight and put my knees together, my ankles tend to go outwards.
I didn't know it's a problem because I feel fine and I can walk and run (not very fast) but i can still move.
He then told me to sit on the floor in front of him and so I sat down and he says i "w sit" which isn't good but its pretty natural for me, been doing it since I was a kid.
I think they are just trying to get more money.
If you don't trust him, then go to the doc that gave you the referral.
I've had good luck with physical therapists. It's like going to the gym but having a person who really knows what their doing to give guidance.
Two reasons I am hesitant is because i don't have knee problems that I know of. Ankle problems, yes, but not so much knee.
Other reason is because he made a big deal about the "w sitting" but every girl does that because when you wear a skirt you can't sit how they are saying is the best.
When he described it to me what I am supposedly doing wrong, he even showed me a pic of brittany spears and said, that is what he is talking about. Which is stupid because showing Brittany spears proves my point that every girl does it, so now I guess I am broken and need repairs I wasnt are of..........
I see differences in the bellhousing patterns on these. Both look identical otherwise as 727. Could 1 be an AMC? If so, is that the only difference, just the bolt pattern?
Bellhousings.....I like bellhousings!!!
My most treasured one is for a 64 slant six to 4 speed. They are rare although many don't think because they often generalize it as the same as a mega common 3 speed bell which is completely different
Hey Ms Rani...do you see the differences on the bolt patterns of those two? Do you know what the bottom one is?
The bottom one really looks like a small block 727 to me.
That is what I thought when I first saw it
That is what I thought too, but there isnt a centered top hole like a small block has. I need one and wished it was
Well, I am home again, and managed to find some mini mag light light bulbs. Had to drive to a town 20 minutes away. They are mostly sold out on flash lights, bulbs, batteries, lamp oil and lanterns. One store had sold for $20,000 the last 2 weeks.
Bill
Also, I have a set of carbs. They appear to be 600 cm vacuum secondarys but I have never seen them without choke horns. They were not milled off later... Anyone have ideas or seen them like this before?
It is a small block.
Try it and I bet you it is. I don't think there is a centered top hole, I am 99.999% sure that IS a small block 727
Well now I have to run back out there. My 340 has a top centered hole...and it does for sure. Hmmmmm
But, you are right!!! Just dug out my 727 transmission handbook and it matches for a small block.
Bridge is getting final layers of asphalt. Yay!
Railings and pull barricades, couple yellow stripes and we can travel across without traffic lights. Been 5 years with those lights. Some days if i travel across often, i bet i spend 30 minutes waiting for a green light...
