Ddaddy
I'm changing the World... one pixel at a time!
Holley made them that way too, with no choke horn from the factory.But these are vacuum secondarys and single accelerator pump
It's more than OK to be hesitant. Get another opinion/analysis.Two reasons I am hesitant is because i don't have knee problems that I know of. Ankle problems, yes, but not so much knee.
Other reason is because he made a big deal about the "w sitting" but every girl does that because when you wear a skirt you can't sit how they are saying is the best.
When he described it to me what I am supposedly doing wrong, he even showed me a pic of brittany spears and said, that is what he is talking about. Which is stupid because showing Brittany spears proves my point that every girl does it, so now I guess I am broken and need repairs I wasnt are of..........
sometimes knee problems can cause ankle problems. Actually, it’s true with any body part. Last year I was having a ton of back pain in my lower back and hips, ended up being a torn lumbar right up by my shoulder blade.Two reasons I am hesitant is because i don't have knee problems that I know of. Ankle problems, yes, but not so much knee.
They sent me more info to my email.sometimes knee problems can cause ankle problems. Actually, it’s true with any body part. Last year I was having a ton of back pain in my lower back and hips, ended up being a torn lumbar right up by my shoulder blade.
Atleast from the photo, that looks like refinish, so could have been milled off.They were not milled off later... Anyone have ideas or seen them like this before?
Farr out man!
The Holley "list" numbers are on the air horns. I don't think they are stamped anywhere else. Those carbs are either 390 or 600 cfm if I remember correctly.Atleast from the photo, that looks like refinish, so could have been milled off.
I've not found the casting number to be much help - to a carb guy who keeps track of such things, they might be a clue.
Keep looking. If it came from the factory without the choke horn, then the list number will be somewhere else.
If it was done later, most shops stamp or mark them, but a lot of folks don't.
Check the top of the metering blocks as well. The older factory metering blocks often have the carb list number stamped on them, sometimes in addition to the block number.
Don't think so. AMCs that I have use a Fomoco starter on the passenger side.Could 1 be an AMC?
I dont know if you wear high heels a lot but I do know the doc told my wife a lot of women have that issue, particularly from wearing high heels.They sent me more info to my email.
They said I have this problem.
I am exactly like this but seems normal enough to me. If you look around I bet a good majority of the population is the same.
Either way, it kinda wrecked my day because I am paranoid now and keep looking at my knees
Get a pic of the pan... or better yet, a pic of the numbers from the pan railI see differences in the bellhousing patterns on these. Both look identical otherwise as 727. Could 1 be an AMC? If so, is that the only difference, just the bolt pattern?
I wouldn't sweat it too much. If doctors are trying to make us all the current version of perfect, I'll just accept my 'less than perfect' body as is. Never hurts to get a second opinion tho.They sent me more info to my email.
Every day.I dont know if you wear high heels a lot but I do know the doc told my wife a lot of women have that issue, particularly from wearing high heels.
They are when they are made with no choke horn. That's a big thing now - you know - big buck carbs from the manufacturers.The Holley "list" numbers are on the air horns. I don't think they are stamped anywhere else. Those carbs are either 390 or 600 cfm if I remember correctly.
That is a condition that needs to be addressed and it is not normal. Only a small percentage of the population has it and if you don’t do the work to correct it now, it will be serious trouble when you get older.They sent me more info to my email.
I've had days like that.I shouldn't have got out of bed today.
My life would be a whole lot better now if I'd never left the house and called in dead to work
Possibly but I’m no doctor. Just going off what my wife was told about the same thinEvery day.
So you do think it's an issue??
Oh don’t talk like that. Stuff happens. You’ll manage and be fine. Go see a specialist, do the therapy and you’ll be fineI shouldn't have got out of bed today.
Are the 'HP' series the first 4150/60 models without choke horns? If so, then the only other place I've seen the number is on meter blocks - sometimes.The Holley "list" numbers are on the air horns. I don't think they are stamped anywhere else. Those carbs are either 390 or 600 cfm if I remember correctly.
Tell you what. Those are probably older carbsAlso, I have a set of carbs. They appear to be 600 cm vacuum secondarys but I have never seen them without choke horns. They were not milled off later... Anyone have ideas or seen them like this before?
