I thought someone would like to see the bracket from Vintage Air, this will mount the Sanden 508 compressor, alternator, and the PS pump, it mounts to the water pump and they give You all the hardware/spacers to mount it. It comes in bare metal.
Thanks so much ,I have factory air but the ,bracket tensioner is missing and very hard to find,Thanks againThis mount kit will not fit the 66. They have one for 69 and earlier, I'll get the number tomorrow. It looks like it will work fairly well but moves the alternator to the driver's side, if that might be a problem.
I think oldmanmopar will have what u need. KimThanks so much ,I have factory air but the ,bracket tensioner is missing and very hard to find,Thanks again
How do I contact him.ThanksI think oldmanmopar will have what u need. Kim
Thanks Kim.Look him up in the members. He reply’s to wanted ads. Kim
Start a want ad is the way to do it.How do I contact him.Thanks
What did it cost? I also wonder if the compressor is available with a serpentine belt to match the March pullies? That would be cool!I thought someone would like to see the bracket from Vintage Air, this will mount the Sanden 508 compressor, alternator, and the PS pump, it mounts to the water pump and they give You all the hardware/spacers to mount it. It comes in bare metal.
The kit is as you see it. Only 3 of 4 compressor holes are bolted to the main bracket.So what r u doing for the bottom bracket at the T stat housing? Kim
I tried to PM you but your box is full. Don't want to hijack this thread.That would be great ,could you send a pic please
