At long last
Evan Dutch
North Carolina
Hi all. It’s been quite a while since I’ve posted on here last, it’s been even longer since I first tossed around the idea of building a shop. I’m happy to say that it’s moving along nicely!
Very nice. Congratulations
Looks a little different than your old one. Nice job!
I’ll either do that or bring in some gravel. Most likely gravel since it’s cheaper.
Get some of those dry stack blocks, and build a retaining wall about 12 feet from the right side first. Build it up just high enough to be even with the bottom of the building, then add your gravel. That will give you a good level place to park, and also make it level going in your walk in door. Nice shop!
Nice unit, mine is 24x36 with a 10x20 out the back, I thought I was set but little did I know that over the years the thing shrinks, now I can barely get around in it. It only has 1 car in it, a 64 Barracuda.
