Splittin hairs. Put the 518 in it and gear accordingly.
Here ya goYou will need to clarify what you are talking about here .
To find your cruise timing at that rpm; (edit; minimum cruising rpm), just keep tugging on the timing, while simultaneously reducing the rpm back down to the minimum cruising rpm, until the engine no longer builds rpm. Edit; I use the fast idle cam to set the minimum cruising rpm.So for example; you add 3 degrees timing and the rpm goes up say 200rpm. You back it down the 200 and add 3 more degrees. This time it might only rise 100rpm. So you back it down, and add 3 more and this time it goes up only barely, so you take the last 3 degrees out and call it done. End Edit.
Small blocks 340/360 get about the same mileage it doesn't matter what you do.
If you veer from stock cam into performance cams... the mileage just goes down at a certain point.
15-17mpg.
318, little better .now Slant 6... 40 mpg ,mother f'r, just ask any slant owner. Lol jk
An interesting conversation for sure.
I went from 17mpg average at 75-80mph with a stock 318 four barrel with headers and a 904 to a mildish 5.9 Magnum and the A500 with lockup (barely ever use lockup and have it turned off most of the time.)
2:73 rear gears and a 25 inch tire.
At that same 75-80mph with the Magnum and A500 I am running right at 2,100 in the rpm's and get 25mpg on the hiway.
My cam is 214/224@50 with a .512 lift and carb is an Edelbrock 1406 (600cfm)
I also run it on the lean side (around 15.5-16:1) and about 18 degrees initial with a total all included timing of 52 degrees or so.
So basically at 75-80 which takes about 1 inch of throttle at the pedal I am running a slightly lean condition and lots of timing.
Now ya got me trying to figure out why some peoples mileage stays the same or even goes down.
I'm about ready to swap in a 3:55 geared A body 8.25 sure grip, so I'm expecting I might be into the throttle a little more out of pure enjoyment, but it will be interesting to see how much mileage I loose.
Don't expect it to be much, but I do expect some loss with an 800 rpm increase at freeway speeds.
I have never ever been able to get a slanty up to the numbers of a hi-compression 360, even after I took it apart, and boosted the compression up to a true 9.5. And spent way too much time sorting the combo. Total waste of money and time....... compared to what I got out of my 367 .
Check out TBs post.
Good point. After all, 38 mpg’s out of a Hyd. roller cam @ 224@050 that revs to 7K in that is amazing. Even runs on Yak piss 87.We've already figured out your 367 is at the top of the heap. Just ask you.
