Compression test results and plug color question.
MileHighDart
Lakeview, OR
So the other day I decided to run a compression test on my 5.9 magnum. Haven't done one since I put the engine together a couple years ago, so just decided to check it out.
Numbers look pretty even across the board, all between 139 and 144.
Plugs look kinda of black and sooty probably because the choke was on most of the time when I was warming it up before the test. (im guessing). But I know it's probably running a bit rich too.
So most of the plugs are black or brown, but wondering whats up with #8 ?
Looks bright white compared to the others. Any Idea why that one looks so lean?
What plug is that? You definitely have some distribution issues but number 8 looks the best at cruise. The rest of it would be a guess with the shells on the plugs but if it's that pig rich at idle and cruise it's probably pretty rich at WOT.
What carb and intake? Cam timing?
[QUOTE="yellow rose, post: 1972736343, member: 4180
What carb and intake? Cam timing?[/QUOTE]
Edelbrock Magnum airgap. Edelbrock 1406 carb. It's got a 5.2 Magnum cam. Don't remember all the specs right off, but I know it's 112 lsa and 110 installed center line.
P S. I am getting ready to finally install my Innovate air/fuel gauge so I can dial in the carb a little better.
number eight does looks odd, kinda like a head gasket issue where it is sucking coolant in the combustion chamber
at 5307 feet above sea level...i would be changing some metering rods...or jets around.
What's that plug read from? Did you just take um out after driving around or did you do a wide open blast like you're supposed to and cut it immediately off? Exactly WHAT are we reading here? If it's idling in the driveway, They look pretty dang good.
Yes, it was just idling in the garage till warmed up. Didn't know about doing a wide open blast before pulling the plugs. And I didn't really pull them to read the plugs, but to do the compression test. Just thought I'd ask what you guys though cause #8 looked so much more white than the rest.
Yeah. You caint read plugs like that. You're supposed to get it up to temp, do a full throttle blast through the gears and "I" always shut r down before I even come to a stop good so the engine doesn't get into idle at ALL. Then look at um. Opinions vary, but that's MY method.
thankyou
There was a pretty well known racer around Tulsa quite a few yrs. back , had a new 426 stage 3 wedge, 63 plymouth. He was going to do a plug read/chop the throttle , throwing it in neutral/shutting it down at the same time , to acuratly read the plugs. He went thru neutral into reverse , he ended up with jaws wired closed , and sold the drivetrain to another friend, that's all that was left !. He quit dragracing .
Having a reverse lock-out (like on the B&M Pro Stick) takes some getting used to, but I like it to avoid the risk of this sort of thing.
ALSO if you have a locking column be careful shutting down, you need to be able to go where you planned!!
Those car were NOT play toys, even in "stock" form. If you can call it stock.
Exactly why they are NHRA mandated. I've always like them too, but they are a trick to get around quick sometimes.
My local Mopar machine shop (that has built and raced Mopar engines for many years) has mentioned to me that it's not too unusual to have some fuel distribution variance, in particular, to be leaner on #8. Something about it being an end cylinder in combination with the way the firing order is designed.
And maybe this would be worse at idle as well???
(this according to my memory of a conversation months ago, so... you know.) :)
There are 4 cylinders with an extra corner in them, even with a single plane intake.
I'm thinking (not ready to test yet) that some of those distribution issues are really reversion related. I can't prove that, but that's what I think.
Do you have a PCV, and where is it connected?
Might be the answer this time, but Rob is spot on about plug reading.
Be careful if you have power brakes before shutting it down.
Check port alignment to head.
Disconnect the pcv, plug it and drive it cruising, no wot and then check the plugs again...who knows.
Everyone else have covered most things to check. Shortest wire of a set of crappy high resistance plug wires perhaps, lol. Maybe not, maybe you have good wires...maybe you fouled the plugs at one time, short of that one and they never cleaned up. Lol
Not many reverse lock outs around in 1963--------
Agree with this post, we flowed 3 diff. intakes and there was a bunch of diff. in them , read hughs intake tests.
I got the victor down to 15 cfm scatter, and a toquer 2 down to 25, a weiand team g down to 24 , and I aint no pro -----
Would love to have Wilson manifolds do one for me , but $1500 is a too much for me !
