What Are You Doing To/With Your Car Today?
I pulled the spare slant CT26 turbo I got free at a swap meet to look about rebuilding the cartridge (where the bearing are) as the shaft was very loose. Come to find the cold side housing was hit with a hammer or something and was cracked so it was junk. I also found a rolled up cigarette pack sucked into the inlet, all the way down to the compressor wheel! Also swept under the garaged car and found a bunch of wrenches that I left under there doing something......wondered where they went.
Well, yesterday I finally did what I said I was going to do last weekend.
Got the Dart up on jackstands as high as I could get it. Unpacked my new transmission jack, and got the 904 out.
Time to start bending brake lines , look at all that glorious room
Started front end rebuild on the 69 Dart. Got a 12 ton press from Harbor Freight for $103.00 I'm using for the bushings. Going to do my 66 Coronet next. Not as bad as I thought thanks to this forum.
It's for a 1972 Dart with 4 wheel disk brakes.15/16 bore. Got it from Dr Diff. It's a quality piece. :)
All most ready to put engine and tranny in the hole just have to pull dist. and build some brackets to lift it in.
Truck is sitting in the rain getting washed..... Tomorrow..... Drive the piss out of it.. Back to work you lazy street bum. 1977 Dodge D150 Warlock Daily Driver for Soon to be 43 Years !!!!!
What you got something to say about it !! I think he has paid his way ??????
Your a little too far away. Unless you wanna drive from North Dakota to Michigan? :)
