Upper radiator hose - 71 and up type radiator
shifty
New Haven county Ct.
Ive got a waterpump that sends the lower to the right side, Ive got that figured out, My upper is an issue, was running a universal flex hose but its starting to kink, I tried a 55091 upper that is universal and has a 90 degree at the T stat neck but its too long and I dont want to trim it down to the corrugation, anyone have any thoughts on a upper hose part number that attaches to the radiator upper left ?
I'll go ahead and ask for everyone, what is it we’re a workin’ on here? Can you post pictures of your predicament?
here is a picture.
My upper hose is from NAPA. I don’t know if this is the P/N but it is stamped K23C0AG.
I ordered an upper for my 383 w the 22" radiator, and same thing, it kinked and wouldn't fit correctly. I finally lucked out and a guy had one in his shop, it was dusty, no visible #s, but fit perfectly.
Hope those part #s from Garrett and Customs work.
If not, You may need to try an assortment of trial and error.
Mine is identical to the pics from OldManMopar. Running a 22 inch Modine two core on an LA.
Dayco part number 70975. (pics above)
Its listed as "cut to fit", not universal. Just trim ends, as needed.
Went thru a sack full of upper and lower hoses to get a good fit.
