How to recondition "coated" interior panels?
Rod 69 Cuda
Active Member
Massachusetts
How do I restore interior fastback panels? They are plastic/vinyl/rubber coated over tin. Do I use rubberized paint? Textured paint? One section has rust under the "coating" which is bubbling, can I sand the plastic/vinyl/rubber top coat away to get to the rust, treat it, then paint over with something? What is the best method to restore? Thanks
Have the same issues with mine. I chose to buy the carpet kit for mine even though they were not carpeted originally.
They make a matte black, textured powdercoat.
I'd have them stripped and done that way. I used it on my dash.
Hello 4SDT, Can you send an image of carpeted side panels? Just curious how to trim/edge the carpet and how it looks? Any before/after photos? Thanks, Rod
Sorry, my panels currently look like yours, but someone on here will have some pictures of carpeted ones from their car. You can order them pre-cut.
That is a great question and I don't know the answer. I found a nice pair for my 383-s in a junkyard many, many years back. It was a great day when I found them as they were in great shape, with no speaker hole cut out in them, which is quite common. Here is a picture of my 383-s I sold a few years back, had it for 25 years. Rod
Hi Rod, lemme do some digging for some previous pics. Cuda is currently in storage so I cant get any current ones.
Not sure on the texture of the originals (I own a notch back) but there are a lot of things that can be done with the various bed liner coatings to get different textures. Eh, just an idea on something to look in to!
Sorry to hijak - did you make that gauge cluster yourself? I'm wanting to do something similar for my '67. I'm not a fan of the factory ralley cluster - and would rather go aftermarket.
It was from a company that is no longer in business called rocky mountain dashes. Later it re-opened as PEak Dashes.
There is another source to get them from located in this thread.
Re: Peak Dashes
The pre 68 bucket seat backs and skirts were made the same, vinyl attached to steel with contact cement. I've repaired small cuts/various scars in the vinyl on those parts but I didn't have the rust issue. The carpet is probably your best route.
