Post 11 second small block combos
Updated time - 11.77@114 @ 5900ft da (Sea level is gonna be a blast)
I broke some top end stuff, so ended up buying new trickflows and getting it all sorted. This was the shake down run 32* total timing and baby soft launch, 1st and 2nd gear were shifted at 5500rpm and it sounded and felt good so I let it ride out 3rd, now through the traps at almost 7000rpm (6400-6500 with the other heads).
2nd run, Shift light set at 6500, footbrake to 2500, timing at 34*. Launched so hard it threw me back in the seat and pulled my seat mount through the floor which caused me to shift into 2nd about the 60ft mark. Still ran 11.83. I guess i'm gonna need to strengthen some stuff.
Update ish..
11.72@114.12 @ 7,859ft DA...still all steel minus back seat.
What top end stuff did you break??
Few things... But the one that really pissed me off was the helicoils for the rocker shafts were pulled out and Bam. Not gonna use bolts again. lol
What was your assessment? Soft aluminum, poor threading and helicoiling? Not enough bolt thread engagement?
I'm guessing poor threading and helicoil.. I threw the heads in a box, i'll trya nd fix them later, maybe i'll get lucky and use them on another engine.
What were the springs, cam lift and rocker ratio specs you were running? Thanks
Howards solid roller, .640/.645 1.5 rockers.. can't remember the springs, but they were even on the light side for a solid roller cam.
73 Duster , former drag car, converted back to a street car, front seats only. 3240 pounds with me and a full tank of E85. Stock bottom end 318 Magnum, 150k not rebuilt, $150 Craigslist shortblock. GT45 turbo, 2-1/8” OD crossover. Stock cracked heads (they didn’t leak with alcohol in the chambers), kegger intake, stock throttle body. Megasquirt 1 controlling fuel only lean burn distributor to lock timing at 20 BTDC, MSD 6-AL. Comp shelf cam,(.506 lift with 1.6, 216 224 @.050, 114 LSA, better valve springs, ARP head studs, Cometic head gaskets. PTC 9.5” 904 converter, A999 trans, 8-3/4” with 3.23 gear 35 spline spool, 35 spline Strange axles. Mini tubbed poorly, springs relocated, Cal Tracs, split mono-leafs. Stock rear shackles. Stock tank with 1/2” pick up and a 3/8 return. 80 lb hr injectors, AEM 430 E85 pump. 3/8” supply and return lines. Non intercooled, car is not cut. Mickey ET Streets 325-60-15.
Slip is on 20 psi. Ran 121.63 on 15 psi.
I do have to make a correction, right now I have the PTC converter in, during these passes there was what I think is a 4500 stall j converter. I sort of blow thru it in the video, hopefully it won’t be as bad and I make a 10 second pass with the Craigslist engine.
Eventually I will build a better engine (goal is a low low 10 second car in hot weather) with forged pistons, better rods and a forged stock stroke crank.
1975ish Duster....has 70-71 front grill and bumper on it...
360 .030 with seal power h116cp pistons...5/64 ring pac
Chinese cornoavirus free h beam rod....725 grams
Speedmaster CNC bare....local machine shop did valve job
PAC 1903 springs....
Speedmaster 2.02/ 1.60 valves.
Speedmaster steel retainers and locks
MP 571 oval cam shaft...P4529973
Crane 1.6 intake 1.5 exhaust
Holley SD with QFT 750 dp on E85
MP race electronic distributor with msd 6l
TTi 1 5/8 stepped headers
TF 904 with 2.74/1.54 gears....8 3/4 4.30 rear gears
8 inch converter...ptc i think...lol
9 x 28 mt slicks.....
3000 lbs with driver....still has heavy rear bumper...
Ran 11.192 at 118,56.....probably a 10.90 at sea level....
Chinese cornoavirus free h beam rod....725 grams.
What did you have for cylinder heads and any work to them?
I updated the engine specs....
and the rods were in plastic bags...have had them over 5 yrs now...
I haven't been on in a long time....69 swinger ...factory 340 4sp....well that was many years ago...lol...
340 with: 318 dump truck crank...JE pistons 11:1..factory rods... .20 over...roller comp cam .605 lift..crower lifters.
W2 race heads..2.02 Manley valves..I ported and polished them...mopar intake..750 holley...
904 trans...4.88 moser axles..3200lbs...
just tested once at Atco many years ago...she ran 11.50s 116mph easily...with mufflers and 275 M&H street slicks...I think she might see 10.90...she ran lean I jetted it and it needed more...I figured open headers use the trans brake...and slicks...and a 850...
Updated time
11.57@117.8mph at 6989-7100ft da (multiple sources showing different DA)
Last update till I hit 10s.
Locked timing at 32, adjusted caltrac bars and shocks.
6942ft DA car #299
318
Bored 030
360 heads. 1.88/1.6 valves. Ported
Kb399 pistons
Scat-i rods
Stock crank
Comp xs282s cam
Headers
Tunnel-ram+2*465carb
Tf 904 manualvalvebody
4000stall
4.11 rear end
Stock suspenssion= Leaf springs
Best et 11.85/184km/h 184km/h= +114mph
Car weight 1200-1300kg = 2650-2850lbs
1967 Dodge A100 panel van 410 (Blueprint LA short block .040” over approx 9.8:1) Iskenderian 280 adv/ 232@.050” .517” lift (w/1.6 rr) 106LSA/102 ICL, mildly ported 1.92/1.62 valved EQ Magnum heads (LA intake style), Comp Cams 1.6 Roller Rockers and related valvetrain components, unported Edelbrock RPM AG, AED 750HO dp, Dougs D453 headers w/12” long 3” dia extensions, Crane HI-6N ignition, FABO plate on Chrysler electronic dist w/22 initial, 32 total, cold air intake/air box, 727 w/Transgo manual VB, Turbo Action S-800 10” 3500 tight converter, 4.10 8.75 sure grip. At Rockingham Dragway (elev 426’) multiple December 2019 55 degree weather runs in 11.75-11.82 @ 110-112 range, weight at that time with driver was 3570lbs give or take. July 25,2020 run in sweltering 90 degree heat, same setup but with van weight reduction of 200 lbs (now 3370 lbs w/ driver, 3150 lbs van only) and addition of double adjustable QA1’s front/rear, only run I got in was a 11.98 @ 109+ Was setup for a better run in the slightly cooler evening but had line lock brake drag issue and ended up running a throwaway run. Will be shooting for runs in similar cooler weather come fall for a better apples to apples comparison (from the 200 lb weight reduction as well as learning the shocks) So high 11’s now, with weight loss, shocks and better temps I’m hoping for something in 11.6@113 range maybe better :)
I was hoping i would of got to add my build to the small block 10 second post. But for now I will have to post here.
I have a 96 SB 2 wheel drive Dakota.i am guessing 3400 pounds with me in it.
2000 360 magnum block
Factory cast crank
Stock rods
Stock bore with KB107 pistions
Comp 550 solid lift
Smith Brothers 3/8 push rods
Out of the box trick flow heads.
PRW 1.6 Roller rockers
Ported indy cylinder head single plane intake
Holley 650DP ported to flow 800cfm
2 inch super sucker carb spacer
Hooker 1-5/8 headers
Turbo action built 904 transmission, stock gear ratio
Coan 8 inch converter, 5500 stall
Ford 8.8 rear-end full spool, 4.30 gears
Weld prostar wheels 15x3 front, 15x10 rear
Hoozer 28x9x15 slicks. Best pass so far has been
60 foot 1.57
1/8 mile 7.15
1/8 mph 95
1/4 mile 11.23
1/4 mph 115
Factory cast crank
Stock rods
Comp 550 solid lift
60 foot 1.57
1/8 mile 7.15
1/8 mph 95
1/4 mile 11.23
1/4 mph 115
I love this picture. Lol
