Will a 1967 B body floor shift column provide the parts needed to convert a 67 a body column?
crawsfire
TX
Title says it all. Can I use a 67 B body floor shift column to convert an a body column shift to floor shift?
thanks
Just change the shaft itself. We used a '67 Charger column with A-body shaft in this car.
thanks
I don't know the answer to your specific question, but I do know you can use a 67 A-body column shift column to convert to a 67 A-body floor shift column. All you need is an angle grinder with cutoff wheel (or saw capable of cutting metal), small piece of scrap sheet metal, epoxy/body filler, paint, and time.
