Cragar 61615
pete9857
cincinnati
Will these Cragars fit a 75 disc brake Dart? Is the hub size compatible?
Don't know if this helps, but I have those wheels on my 73 Duster - BBP, 15x6. I am running with the "Right Stuff" disc brake conversion setup their SKU MDC66SDS. I think the rotors are stock spec. No problems.
Yes they fit, but I don't like the the lug nuts keeping the wheel centered. I called Cragar, they don't have a collar to make them fit snug on the hub. I'm going to look into maybe getting some made.
Those are called Hub Centric Rings and I ordered mine online and they were a perfect fit.
Problem is, I don't remember where I ordered them from.
It was a place recommended by another member.
Jegs carries them also.
Detroit Wheels Hub Centric Rings | JEGS
Did you ever get the rings you were looking for?
I'm going thru the same thing now with my Crager rims.
