If the goal was increased low lift flow, from like closed to .450 or so max, would the valve job strategy be any different?
@yellow rose , I'd be interested to hear your opinions on this also.
For the intake side I'd use:
46 at .080 wide
50 at .045 wide
65 at .110 wide
75 at .110 wide
80 at .200 wide
I can't find the exhaust cutter I'd use but it would be a 50 seat with a 44 degree top cut .120 wide and a radius off the bottom of the 50.
The exhaust is going from memory but that's pretty close.
And as PHR said earlier, I'd sink the valves until the top cut was all the way in.
I'd try and use a 2.02 valve if possible but nothing bigger than a 2.05 if I couldn't get that valve job in there with a 2.02 valve.
Edit: forgot to mention the exhaust would have a fairly large tulip to it and the intake wouldn't be a nail head. And if I could avoid it, no back cuts.
I'm a bit apprehensive about running a 50° seat in such a flat chamber, one would have to sink the seat quite a bit to get this profile. But I'd love to try it.
[QUOTE="yellow rose, post: 1972786972, member: 41803"
Used to be when someone said "sink the valve" anyone standing there would go apoplectic, lose all the color in their face and then they'd call a priest in to do an exorcism on you for speaking that voodoo.
No problem I did what I could now you can continue...You guys carried the banner well today so after church I stayed housebound. Lol. You guys make valve jobs way to complicated.
Holy sh** Batman! That's bookin'!Ok guys I finally got this head back on the bench to flow the exhaust after what I call shaping work. As I told you guys before I was told by a head guru (Darren Morgan) that speed on the exhaust side was more important than flow so who am I to argue. (Target as close to 325 as I can get) Again I am super impressed by this exhaust port and how quiet it is so I said to myself let’s not get stupid so I stuck with the valve job as it came from Speedmaster. A 60 degree cut and a 45 seat. Airspeed before after just chamber work maxed out at 270 (very nice number). Tonight after porting max airspeed was 332 FPS. DAMN!!!!
Ain't that the truth. Then you try to explain the virtues of seat profile vs seat height and they stare at you like a deer in the headlights.
You have looked at a lot of ports. Can you figure why these are so good?Flow numbers
———-stock——-ported——-gain
.100——-34————-40————+6
.200——-95————104————+9
.300——-135———-143————+8
.400——-159———-175————+16
.500——-172———192————+20
.600——-179———202————+23
.700——-181———207————-+26
.800———————-210
I never flow these ports this high as they are usually stalled way before I get this high.
Ohhh well back to the flowbench. I really didn’t want to get sucked into getting crazy on these but I gotta give the intake side one more attempt before I throw them on a shelf. I’m at 202@.300 but only 278@.700 lift. Floor work needed but it’s begging for a 2.05 valve.
When it comes down to it, those who go deep...end up at the floor. Iirr... in this very thread, a certain someone spoke against it.Ohhh well back to the flowbench. I really didn’t want to get sucked into getting crazy on these but I gotta give the intake side one more attempt before I throw them on a shelf. I’m at 202@.300 but only 278@.700 lift. Floor work needed but it’s begging for a 2.05 valve.
Wayyyy.You guys carried the banner well today so after church I stayed housebound. Lol. You guys make valve jobs way to complicated.
Wayyyy.
915 J 1971 casting
73@.100, 147@.200, 204@.300 249cfm@.400, 278@.500..and its 186cc
3 angle valve job , hard seats on int proud in the chamber. Most of the work in the roof ,widening the port , and leveling the floor before the turn...guide skinnied n left long.
I pass on all those experimental / oddball seat angles. Longevity is more important to me and ultimately I get where I wanna go, just fine , without it. It's there if you search hard enough... I have spent a weeks time, conservatively here and there, on one port, in order to find it. Back cuts, sets angles...worth 4-9 cfm, sometimes... other times they speed the air and create a revisit somewhere else to correct the fall off. Gordon said it earlier in this thread, something like or about how to just get "close enough" to the goal, in some heads, is good enough...because that next move can sometimes bring headaches.
You definitely can find more in that head, you may or may not trade 4 cfm down low to see those 290's... I doubt it... but you have a good12-15 cfm waiting on the next page for ya.
What's not reliable about a 50 degree seat?
The funny thing is I know there are many guys out there doing some variant of a 50 on everything from street cars to their race stuff.
I've used it on 2.3 heads, and last time I checked on that engine (mid December) that head is still the best they've come up with, and it's still the best on the dyno and at the track. And that's after Esselinger squealed like a stuck pig when the found out I was not only changing their valve job, but correcting their crap CNC porting.
I know, for 100% surety, that I'm not the only one who doesn't pick a valve job based on lift. I know personally (through PM messages and such) that there are guys who are using some variant of a 50 on lift rule stuff. All under .500 lift. And it works.
I've never been fond of doing R&D for free, but I've also never sat back and let technology go by without doing my own investigation. And making my own judgment.
It doesn't take long on a flow bench to understand why steeper than 45 degree seats are becoming the norm. Irregardless of how much David Vizard and a bunch of other guys harp on low lift flow and flatter than 45 degree seats for less than .600 lift stuff.
If flatter brings up the low lift and steeper helps the high lift, make sense I'm good at 45 cuz I'm not playing at 600 plus lift playground... everytime having to re face the 45 degree ootb valves,eh.. I'm okay not making it more complicated or time consuming. I dont doubt it can help somewhere, but nowhere I've seen.
