1969 Dodge Dart - Original Radio Speaker Ohms?
Lord Sparky
Carlsbad, California
I am about to test to see if the original radio works by hooking it up to a new speaker that can be setup in 4 or 8 ohms. Does anyone know if the original radio was 4 or 8 ohms?
pretty sure 4 ohms...
but here ya go
"Generally home audio uses 8ohm speakers and car audio uses 4 ohms or 2ohms. Most likely you car audio head unit or amplifier is going to be designed for 4 ohm speakers, but its OK to use an 8 ohm speaker on them. But 8 ohm speakers on a 4 ohm system only need to be rated at half the output power of the amp."
I can't find the site but I have seen it twice looking for a stock speaker for my dart.
I recall seeing that 8 ohms is correct as 4 ohms increases the current in a transistor and caused it to run hot.
I'll keep looking for the site
Found the link
Classic Car Speakers
Thank you for your replies, but alas, the old radio was dead. I will be purchasing one of those expensive new-fangled ones that looks the same as the old. It looks like some water got inside the old radio--all it made was a low hissing sound.
that's the water cooking off. you just need more voltage :D
Found the link
Thanks Dana.
I noticed the replacement speaker in my car is marked 4 ohms and when looking by the part number on line found a refurbished original for sale. That place also says its 8 Ohms.
One nice feature on the original speakers was the positive and negative terminals couldn't be hooked up in reverse.
Actually these are really not that critical. You could likely toss an 8 ohm in there and not notice much difference
