Speedmaster Small block porting tips and results Part 1
By any chance did you test them after you put them back together?..
not on the one I put together, but I didn't touch the seats and I put the valves back in the same ports. This morning I'm going to assemble the 2nd head, and I'm going to lap a couple of valves just to mark how much contact surface and if the ring is the same width all the way around. That will be the REAL story on this.
That's why I was asking because of toolmanmike's paranoia video :)poke:) on post 495..
I can tell you this, the famed 340's with X heads didn't come from the factory with 5 angle valve jobs.
We better take this conversation over to your thread about home inspection..
This is pretty much a gurus only thread and anything or I should say anybody else their comments will be erased... Ask me how I know...
that was weird I put the little poke in the eye guy's in between parentheses and that's how it came out...
I will post pictures of the lapping ring on my home inspection thread when I get enough of the sleepies out of my eyes. I am slow in the morning waking up....
What the heck! It must be noon there by now... what are you running banker's hours?!.. 6: 30 in the morning and I'm on my second cup of coffee... Just joking I got to go get some coffee...
when you sign off for bed, I'm still up hold'n the fort down.
I wonder if SM even grinds the seats. I bet the seats already have the angle and they press them in and go.
That would be near impossible to happen and even have the valve seal at all.
They are just slamming a quickie valve job on there and sending them out the door.
I'd rather they not even do a valve job at all. It should reduce the cost of the head some, and I can count on one hand the number of times I've used an out of the box valve job on anything.
If my name is on the work, it has to be all my work. It just isn't worth the hassles if there is an issue later on. And for the most part, I'm not big on a 3 angle valve job.
Most ports need at least 4 if you can fit the angles in there and the exhaust should always be a radius.
Well I’ll say one thing, this head just isn’t responding like it should and I’m to the point last night where I started rounding up my old stone grinding equipment. My stone dresser is in need of some pieces so I guess I will be placing an order today or tomorrow. I’m thinking about trying a 75 degree bottom cut. I know a 2.05 or 2.08 valve would help this seat issue but I’m not ready to give up on the 2.02 valve yet.
I agree that a 75 might help. From the pictures the bowl looks like it can take that steep of a bottom cut.
I had my bench set up to flow the exhaust side so while it was in that mode I ported the exhaust. Intake numbers coming soon.
I did lower the shortside a little Sunday (.080) and it responded with 4-5cfm max so we are in the low 280’s at .700 with more on the table.
I think this post ran out of steam. We’ve hit a new low.
I don’t know about other. But I’m excited to here about the latest investigation...........
I'd have to make a phone call but IIRC I had a 45 degree seat that had an 82 degree bottom cut for bowls like that. I know I had one with a 75 but that bowl may want even more than a 75.
I'm all about the 75 bottom/lower cut, do it.
What port volume is this one at to this point?
That's how you get a x,j,Etc to flow
Go right off the hard seat under the valve job.
Deeper the bowl helps if the rest complements such too. If only words could paint a clear picture. You know what you're doing,... we're all just excited is all. Lol
Again going back to the class I went to we were told to never exceed 15 degrees between our seat angles as air has a hard time navigating it. A bigger valve would lower that straight area but for right now I’m trying to help guys out with 2.02 valve info as that’s what 90% of them will be running. If I wanted to hit the easy button I could drop them off at the machine shop, hand over 64.00, and grab a different set of valves off the shelf. If it hits the 282-285 cfm I’m at now and I’m satisfied with the mid lift numbers it’s a win win.
Just asking questions guys. I was thinking something like in this photo. After watching the video I posted above and there's .010 seat runout it makes you wonder if they ground the seats and used the guide as a pilot like they should have.
No way. Nothing keeps its shape when interference fit, if it did...I still say nope.
Again going back to the class I went to we were told to never exceed 15 degrees between out seat angles as air has a hard time navigating it. A bigger valve would lower that straight area but for right now I’m trying to help guys out with 2.02 valve info as that’s what 90% of them will be running. If I wanted to hit the easy button I could drop them off at the machine shop, hand over 64.00, and grab a different set of valves off the shelf. If it hits the 282-285 cfm I’m at now and I’m satisfied with the mid lift numbers it’s a win win.
Thanks for looking out for us tightwads! Next year a valve job maybe in order and knowing the best route would be nice...
I rarely even bother checking that but I know I’m under the 191 cc runner on my best set of heads.
It would have been nice to see what your best valve job would have done with a unported head as I would say 90% of us aren't going to do more than smoothing off the rough spots and a little Port match...
You sure are convincing yourself about that valve job aren't you?..
Doing a little back reading. No convincing here. I'll take mine to Radar and have him correct the seats which will include machining them. If they seal they will work but I don't like the transition into the bowl. What ever it costs I know they will be done right and it's something I can't do at home.
I can probably do that but remember the airspeed was a lot slower on a stock port. But I can check it out.
