mopowers
Does anyone know where I can find one of these? It's an insulator for the steering column on a 66 Dart.
Looks like a motorcycle inner tube might work. Never have seen one available before.
What am I missing? Looks to me like the OP can just re-use the insulator he has. All it needs to do is provide a thin rubber layer between the dash clamp and the column jacket. Most of it will be covered by the clamp; a couple of small splits on the outer edge won't hurt anything, and they can be positioned where they won't show even if someone were to look under the dash.
That's a rubber grommit that goes in the column hole on the small plate that bolts to the big plate on the firewall. I just replaced mine.'Plate 19-14-23' isn't even on my 65 Barracuda, iirc it just goes through a hole in the firewall, anyone confirm? Im at work now.
