Best header gasket for EQ head?
Dusterfreak
Finland
What gaskets you have used with EQ an TTI? I tried Fel Pro 1413 but it doesnt match the port.
Can you razor blade the gasket to match the port?
I've had to trim about every gasket I've ever bought.
I bought Fel Pro 1432 gaskets, smaller holes and much more material under the port, should do it.
Do you have to use a sealant with the remflexs or are they self sealing?
