Garage ideas and tips.
ask if there is a variance for the garage. our area is also 750 sq.ft.,14 ft.peak but there is a 25% variance to add to the square footage.
any size limit on a underground garage?:lol:
Hey all. I am in the process of planning a new garage build. I live in town and have a maximum size of 750 Sq ft I can build. I have lots of yard to use and currently only have a one car. My driveway runs directly by the side of my house now but doesn't really give me access to my back yard. What kind of options do I have? What dimensions can I maximize my Sq ft with? I am considering something like a deep tandem with a garage door on both ends just for air flow and easy of moving stuff around.
I included a shot of my property from Google. You can see the arrangement of the house to garage.
I just built mine a few years ago. I had similar limitations. I was able to go to 766sq/ft though, but with similar height (14' 9 1/2"). Any way...if you are looking for a door on either end I would look at a 25x30 garage. This will give you room for a bench on one side and tools along the other (as you won't have much room on the end due to second garage door). I am 24' wide and can put 2 cars with a work bench on one side and my bigger tools along the other wall. Not a massive amount of room between but workable. Go with an 8' high door (16' wide is nice too) so you don't have to jockey things around getting in or out. I went with full foundation walls in order to add an 18" curb wall around the inside as I know there will be water on the floor at times so it doesn't make it to the wall. My inside is 9 1/2' high to allow for jacking up cars and putting them on rotisserie (I don't have a hoist as not enough overall height to justify it. If I had I would have had to go with cathedral ceiling (losing attic storage space) and it would be centered losing room for 2 cars side by side. As for the attic trusses make sure you ask they make the center open. That way you can utilize the middle for storage. That's what I did and am glad I did.
As others have said never enough outlets (I have them every 8ft) at counter height. As for air I ran RapidAir piping system and LOVE it. Easy to install if you take your time. Won't rust and worth the cost (a little pricey)
As for lights I ran 3 strips of LED fixtures to allow turning on only what I needed...more for things like body work to minimize shadows and such. I also ran gas to mine for the overhead furnace.
Hope this gives you some helpful ideas
I added some pictures of mine. Excuse the huge mess. That was during construction and a family emergency required literally pushing everything in to go out of town to deal with it. Looks much better now. LOL
Mess? Bah! You've no idea what a mess truly is :)
I have the move this piece to get to that piece. Then you realize you need something back where you just pilled everything. Might be a reason not much gets done in the "storage" building. 63 full size Pontiac?
64. Don't have it anymore. Frame was toast from bad storage and squirrels made nests in the rear of the frame arches rotting it out. Sold it to a guy who had one like it for the parts. That's how I wound up with my 63 Dart :) . Also have a 60 Belair sport coupe on the list after the Dart. My counter still has the move this to get to that right now. Have to get that sorted this week.
stand corrected,64. our 64 Chevy rotted out on the "X" part of the frame. glad the Dart has a nice warm garage,looking forward to progress reports. Bob
I built a large shed, roll up garage door, big enough for a car but used as a shed.
I know not a real garage, but there was a height limit on the roof.
I submitted a plan for a lean-to style roof, single sloped flat roof, and was approved.
The amount of extra space is huge.
Also, I'm insulating my garage, currently open studs, and redoing the electric, again.
Putting up a metal ceiling, and moving the electric to the outside of the walls and ceiling with conduit.
Makes future modifications easy and could prevent potential fire hazards.
Installed panel in garage a while back too.
