What motor mounts do I need for Magnum 360 in to 72 dart?
nearpar
The Motor City
Swapping a 2001 360 Magnum into my 72 Dart with the V8 K frame. I need the motor mount brackets that bolts to the engine block. If anyone has a picture that would be helpful as well.
Thank you in advance
magnum changes nothing. Use the same mounts you'd use for a LA 360
Yep you need the 67-72 340 mounting brackets. No confusion here.
Thank you that was what I was looking for does anyone have a part number or a picture of these?
I know someone who has a box of mounts some are Mopar, but I dont know which one I would need. They don't say small block Mopar on them...lol
Found this on Ebay
Motor Mount Kit for Dodge Plymouth 273 318 340 360 383 400 426 440 Engine 65-76
Do these look like the ones I need?
No those are for 68'-69'-70' B body and they are just the isolaters.The pictures I have included are a set of N.O.S. 340 block mounts which would be what you are looking for. Notice how the straight one is wider, that is the pass. side. The 318 driver side is as wide as the straight one, the 340/360 is narrower as shown in second pic.
If you are going to use headers you will need to grind some of the truck mount bosses down on the side of the block for clearance.
Most headers are tight to block on the L.A. blocks BEFORE the Magnums came out with the centered mount bosses ...Especially the driver side.
Those biscuit mounts are good for isolating vibration, but can be torn pretty easy from the driver's side of the engine lifting. I did have to shim them on both cars to get the motor positioned correctly so my TTI headers would not be hitting stuff. I also added the torque tube from Schumacher on my '68 A-Body /6 to Magnum swap, but I believe they are in the middle of a reorg or something. Their poly mounts transmitted way to much vibration into the dash etc, so I switched to the stock rubber mounts plus the torque tube.
I used a piece of hardened chain and a couple grade 8 bolts on my RB powered E-Body along with a set of mitymounts to control the engine lift. I also use a non-solid transmission mount on both cars. It's a stick car with nearly 700 ft lbs of torque, so its even harder on the mounts.
So far, I haven't broken another motor mount since.
