davidcribbs
I just rebuilt my whole front end on my '67 Dart GT convertible. I bought all the products from QA1 and Hotchkiss for the front. I also put on Wilwood discs up front and in the back, just to give some background. With the new front end pieces I had to use a drag link from a '73 A Body, which fit great. I also added a quick turn radius pitman arm and idler arm from Hotchkiss. I just got the car back from the alignment, and the turning radius to the left only goes about a 3rd of the way, but turns great to the right, any thoughts? I thought it might be the quick turn radius items from Hotchkiss, but all the reading I did prior to buying those parts, no one ever mentioned it. I didn't just want to start replacing all my brand new parts until I found the solution, so I wanted to reach out to anyone that may have done this swap in the past to find out if they have had any problems. Or if someone else knew what I am missing that can fix this?
