72 Demon seat wire
Joeycurl
‘72 Demon 440
Bay Area,CA
So I was thinking I had to replace my passenger seat belt because of some other reason.... When I finally got the belt off I saw a set of wires connected to it. Then I looked at my driver's side and they are not there. Then I noticed another set of wires under the whole front seat.
Can anyone shed some light on what these are intended for? I looked at the wiring diagram and couldn't find these anywhere
I believe the drivers side would also, not 100% sure. But in either case, those would be the only two.
IIRC, the switch is at the retractor - turns off light when reel is extended minimum amount. Was hoping someone had some documentation. I can't find the details in the 72 factory literature.
