Jonnylightening
This past weekend i took my Aspen out for a drive. I did a holeshot and when i went from 2nd to 3rd it started missing. Left outta it then realized I had no oil pressure. I jerked it off the road ASAP. I was thinking the worst at first then the miss came back to mind. Maybe a lifter colapsed and jumped out of the bore? Tonight I pulled the valve covers and YEP! Thats it. I swapped EQ heads so im running Summit brand AMC style Hyd. Lifters. Now im not knocking Summit but im kinda hesitant on buying those lifters again. So question is what lifters would you guys recommend? For now im im na stick with the hyd. Lifters but next engine its itsna be mech. Roller
