Stop in for a cup of coffee
Went and fired the fargo. Still purrs. Gave up on shop, son is bringing the bolt bin tomorrow. Then i have to pull stuff off the wall, raise my speaker/shelf and paint the new bin.
Is there a difference between the points ballast and the electronic ballast resistors?
Ha Ha, I know you're not complaining, Congrats!
Best friends daughter returning home from work outside of the province. Thinks she is exempt from self-isolation. Wait until tomorrow when she pops in at the bank to see my wife like she always does. My wife is ready to give her the boot!
You know, other than the ATF spraying on the hot manifolds, there was no oil burning coming from it either.
Can’t get it to idle down either. Thought maybe the electric fuel pump was the cause, switched back to the mechanical, same issue.
And did you use the electric pump? If so did you hook it to ign. on or ign. crank? It may also need a regulator.
