Trans speedo gear number 904
InRogue
Winter Park, FL
I read some wrong info on speedo gears a while back on my 904 as I now have a slew of wrong gears. I have now acquired a chart to show me the right gear to get. What I'm running is a 235/60-15 tire (26") with a 3.31 rear gear so I should be running a 33 tooth gear? Does the lower the speedo gear number make the speedometer run faster. Anyone know how much each tooth to mph the difference is? I presently have a 37 tooth and my speedo is running 6 mph slow according to GPS.
based on your info 6 MPH slow speedo ( Ie your GPS speed is 60 and your speedo shows 54)
At what speed did you get the 6 MPH diff?
Yes
this is all based on the info you provided, but looks like you would be safe with a 33 or 32 tooth I would love to get another reading at speedo 60 and tell me what the GPS says (to validate the results) for the record, i haven't yet, but this calculator is what I will base my speedo gear purchase on when I go from 2.93 to 3.23
Okay I found a spot to get the GPS to 60 mph and the speedo said 50 mph.
Are you sure the speedo didn't say 52?
It's much easier to get the speedo on a whole number like 60 and read the digital GPS.
By my calculations 50 and 60 is not giving 33 or 32 teeth. 52 and 60 does.
Mopar Speedo Gear Chart : Drivin' It Home
We carry many speedometer gears for Mopar transmissions. To determine what gear you need, use the table below. Our part #’s for mopar speedometer gears are FD0xx where xx is the tooth count of the gear.
At 60MPH, 1 tooth = 2 – 3mph.
More teeth slow the speedometer down, less teeth raise the the speedometer. Gears with 25 teeth or less require a different speedometer adapter.
Tooth count table is accurate to within 5MPH.
