Car turns when rolling backwards
gm1236
Massachusetts
I have a 71 duster drag car and when it rolls backwards it turns slightly to the left, steering wheel turns clockwise.
What’s adjusted wrong?
I don’t have any adjustment numbers, front end was set up many years ago and is somewhat worn out.
Thanks
It seems an alignment is in order , turning to the most caster , I think :steering:
I know it’s not the brakes, they are Strang and have very little drag. I’m going with the caster, more on one side than the other maybe?
Drag racing alignment specs; Camber 0* Caster + 1.5-2.0 Toe in 0-1/16".
Simple. Don't roll it backwards.
Under thread tools below the title to the right. I think you can see that as a member.
